Re: -= Ultimate Emanage Tuning Thread =-
Can anyone here post their experiences with using the Target A/F Feature of the Emanage Ultimate?
From what I understand you need Stage 3 wiring, with the water temp boomslang harness, the Wideband o2 harness + Compatible wideband o2.
You could then set your target A/F and do some pulls, then use the Map that the emanage produces as your Airflow adjustments as a starting point for tuning, correct?
Who's used this/ is it useful?
Thanks,
Jason
