Re: Backlash in the Transaxle?
The holes in the VCU wouldn't be all the way through and they woudn't penetrate into the inside of the case. They'd only be ~ 4-5 mm deep, just like the 3 holes that are already in their when it comes from the factory.
As far as the dowel pins holes are concerned, why would they need room for oil? It's not like as if they are moving parts. They remain fixed in the same position at all times.
Declan
Edit: From what I gather the 25 spline 5 speed and 6 speed dowel pins holes are round and they have very little, if any, room for oil.
