View Single Post
Old 07-13-2005, 11:58 PM   #29 (permalink)
ProwlerGT
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (11)
ProwlerGT Level 1ProwlerGT Level 1
Question Re: How to: Flush your ATX fluid and change your internal filter
I heard a rumor that the torque converter fluid is separate from the rest of the fluid in the ATX case meaning that if you drain it doing the procedure I suggested above then you are really never touching/draining any of the fluid out of the torque converter because its sealed off from the rest of the tranny fluid. It doesn't make sense to me that the torque converter fluid would be separate from the rest of the tranny fluid over the rest of the tranny.
Is this MYTH or TRUTH?
ProwlerGT is offline   Reply With Quote
