Originally Posted by skunkworks
good luck!!!
sam
Not sure what I was sniffing yesterday... glad I made it out of cardboard and not metal... not even close. (I keep forgetting how tight the tolerances are around the springs.... really isn't any practical way to grab onto the spring.)
Couple other ideas I will play around with tonight while staring at the head on a bench.
I would still like to see a pic of the Mitsu tool used to remove the rocker arms. I know I have seen a pic but can't remember where.
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
